I once had a Joy-IT KY-024 sensor board that uses the A3141 Hall sensor to output analog and digital signals. I lost that sensor and then bought the Joy-IT KY-003 because I don't need the digital output anyways and the whole board is smaller. The KY-003 uses the A3144 which, according to the data sheet, only has a different trigger point.
The four basic devices (3141, 3142, 3143, and 3144) are identical except for magnetic switch points.
But with the KY-003 I only get an digital output which confuses me because the KY-024 has an analog output that according to the data sheet is a
Direct measurement of the sensor unit
Even if this wouldn't be true, the only components on that board are some resistors and a comparator.
So how can I get an analog reading from the A3144, if it is possible at all?
