I am trying to understand what the temperature profile would be near a 30W resistive heater that is PID controlled to heat a surface to 250C. Correct me if I am wrong, but most wire insulation is designed with much lower temperatures in mind like 70-90C so I cannot connect a regular 2 conductor 18 AWG wire to this heater without melting the jacket.
But how far from the resistive heating element should is reasonable to assume normal wire temperatures?
I understand copper is great at conducting heat but with my 3 meter cable I imagine that the non heater end of the cable is at normal temperature.
How far away from the heater should one install special wiring?
Edit: Looking at the product there is a Molex connector just a few inches away from the heater cartridge. I am fairly certain that if the wire was still hot at this point it would melt the plastic connector. Therefore is likely no need for the second portion of the wiring to be high temperature wiring. Correct me if I am wrong though, but it puzzles me why the manufacturer would continue the high temperature wiring after the connector, except out of extreme caution.
