I read here about voltage dividing. Let's look at this image for the discussion:
Ok so we have 2 resistors in the circuit, and Vout is of lower voltage. But I don't understand - voltage is always a difference between two points. So, with respect to what point is Vout has a lower voltage?
If you say with respect to ground - then, why in this article it says:
Keep in mind not to use a voltage divider to reduce the voltage to supply a device or load because you have to remember that an external device will result in a parallel circuit with R2.
So actually if you take Vout, connect it to the + terminal of a device, and the - terminal to GND, the voltage of this circuit will be dependent on the resistance of the device. So what is this arrangement of voltage dividing good for?
I'm actually asking this because I want to supply my ESP8266 with power from a 9V battery, so I thought of using resistors to divide the voltage. But for this, I need to know the resistance of my ESP8266, which is not shown in the datasheet.
