This is the reality of solar power.
Power sequencing with no load until DC OK is essential with some storage capacitance. Batteries , even tiny ones have huge C values like 10k Farads.
The rating for a PV is max. Solarity into a perfect impedance matched converter called MPPT since **V/I=R(mpt) = Voc/Isc at Pmax ** is exactly the resistance required , R(mpt) needed to get maximum Vmpt*I=Pmax.
This means R(mpt) has a minimum and rises towards high R from reverse diode protection in the dark.
Without a MPT controller if the battery voltage is between 72% ~ 82% of open circuit Vpv or Voc then you at least have a good chance to get > 80% of PV available power from 10% to 100% available solar power. The 82% of Voc is at optimum conditions +/- x depending on PV type.
The input impedance of a DC motor , you might guess is V/I but is actual the coil DC resistance (DCR) to startup, which for an efficient more is 8 to 12% of this ratio which means the start surge from a Voltage source is V/DCR=I or the same as locked rotor current.
Boost converters are like step up transformers where the load is transformed by Rin ~= Rout * (Vi/Vo)^2 * efficiency for steady state. But on startup it’s like a motor with a coil DCR driven by a FET low Ron into an uncharged Cap low ESR, so the startup power demand can be as much as 20x the max rated load power unless it has a soft start. This is to store the energy in the reactive LC components.
The PV is a current source with a Voc limit, but make no mistake, MPT needs a matched impedance to satisfy the Maximum Power Transfer theorem. It is also estimated by Rmpt = Voc/ Isc for the short circuit current. Where in either case, Voc, Isc there is zero power supplied.
So the reality is you need to match the voltage ratio Vmpt/Voc (82% down to less sun @ 72% to convert the charge from a current source into a voltage source ( battery ) with a battery charge regulator ( according the chemistry type) then if necessary, DCDC convert to load with the understanding of the load impedance ratio for input and output gives a product VI = P for perfect efficiency and a motor load and converter load that yield less than 1% of Pmax rating of,PV on startup, so until it overcomes this, it won’t work.
