it's known the following Friis transmission equation:
$$P_{rx} = P_{tx} \cdot G_{tx}(f) \cdot G_{rx}(f) \cdot \left(\frac{c}{4 \pi R f}\right)^2$$
It's nice but, as far as I'm concerned, it works only for a sine wave of frequency f or, with a still good approximation, for narrowband transmission (bandwidth much lower than the carrier frequency).
Now, I'd want to find a similar equation for wideband transmissions, where the transmitted signal spectrum, here called BW (Bandwidth) is not much lower than the carrier frequency. If I were to evaluate it, I'd apply the Friis transmission equation for just the little amount of power around the generic frequency f of my spectrum BW:
$$S_{rx}(f)\cdot df = S_{tx}(f) \cdot G_{tx}(f) \cdot G_{rx}(f) \cdot \left(\frac{c}{4 \pi R f}\right)^2\cdot df$$
where S denotes the Power Spectral Density. Now, I'd integrate inside my domain BW:
$$P_{rx}=\int_{f_{carrier}-BW/2}^{f_{carrier}+BW/2} S_{tx}(f) \cdot G_{tx}(f) \cdot G_{rx}(f) \cdot \left(\frac{c}{4 \pi R f}\right)^2\cdot df$$
Now, my questions are:
Is my approach correct? Do you agree with this result?
Now let's prove why for a narrowband spectrum such an equation should turn to the common Friis Transmission Equation. If BW is small as compared to the carrier frequency, the integrand can be assumed to be constant. That's a consequence of the first order Taylor Approximation of the Antiderivative (here the proof). This means that:
$$P_{rx}= S_{tx}(f_{carrier}) \cdot G_{tx}(f_{carrier}) \cdot G_{rx}(f_{carrier}) \cdot \left(\frac{c}{4 \pi R f_{carrier}}\right)^2\cdot \int_{f_{carrier}-BW/2}^{f_{carrier}+BW/2}df$$
which becomes:
$$P_{rx}= S_{tx}(f_{carrier}) \cdot G_{tx}(f_{carrier}) \cdot G_{rx}(f_{carrier}) \cdot \left(\frac{c}{4 \pi R f_{carrier}}\right)^2\cdot BW$$
If we put:
$$S_{tx}(f_{carrier})\cdot BW = P_{tx}(f_{carrier})$$
we get:
$$P_{rx}= P_{tx}(f_{carrier}) \cdot G_{tx}(f_{carrier}) \cdot G_{rx}(f_{carrier}) \cdot \left(\frac{c}{4 \pi R f_{carrier}}\right)^2$$
Do you still agree with the last result?
