That "operational amplifiers" that could perform operations such as addition, subtraction, integration, were useful for voltage-based analogue computers (that were invented in the 1930s, and the "op amp" invented in 1940s) makes perfect sense to me. But, society has progressed since then. Are "operational amplifiers" still an important tool, or are they more interesting historically just like vacuum tubes are mostly historically interesting although they are still used in very niche cases still?
Context, the term “operational amplifier” itself was coined by John Ragazzini in 1947 for work towards better analogue computers. The device itself was designed for that and optimized for that. Computers use logical operations, and that makes perfect sense. The niche of analogue computers was displaced by digital computers. But the niche of “op amps” was not as it seems. I am interested in why, and asking about what their niche is mostly these days.
The inventor Raggazini was very specific with the use of his device. He wrote in 1947 "it is a simple matter to assemble the particular circuit for any system of equations for which solutions are desired" and "a method for obtaining an engineering solution for integrodifferential equations of physical systems using an electronic system" and "as an amplifier so connected can perform the mathematical operations of arithmetic and calculus on the voltages applied to its input, it is hereafter termed an "operational amplifier". So surely it was invented to calculate the solution to equations. And this makes sense to me. But why they are still so important, is what I am interested in, since they were clearly designed and optimized for something that must have been replaced mostly with digital computation. I was assuming modern uses are either for actual calculations, like their original use was (why they were invented, see Raggazini, 1947), or, that they had a property needed for the calculations that was also ideal for something else. Since this is generally how evolution, incl. technological evolution, works: co-optation.
Reference
J. R. Ragazzini, R. H. Randall and F. A. Russell, "Analysis of Problems in Dynamics by Electronic Circuits," in Proceedings of the IRE, vol. 35, no. 5, pp. 444-452, May 1947, doi: 10.1109/JRPROC.1947.232616.
