I am using the STM32G030C8 and want to use a 6 pin JTAG Needle to program the microcontroller.
In the datasheet for the microcontroller, on page 14 it says:
So I need to connect whatever is programming the microcontroller to pins PB6 and PB7 for example as well as PA14 as this is the BOOT pin. Is this correct?
However it says in the datasheet, pins PB6 and PB7 are for USART- am I correct in saying you cannot use JTAG for this?
How can I find out which pins to connect the JTAG connector to?
The JTAG pinout is shown above. Am I correct in saying I would connect pins 1 and 5 to my VDD and GND nets respectively, and pins 2 and 4 to the microcontroller for programming?
