Background
I have a load at the end of a fairly long cable which can accept a limited range of DC voltages. As the acceptable voltages are quite low, I'm expecting non-negligible (read considerable) losses on the conductors themselves. I don't have the option of transmitting a higher voltage and stepping down nearer to the load.
Maths
I'm not an electrical engineer, but I remember the basics so I've modelled my system as below: where R is the one-way resistance of the long conductor and my load requires power, P (which we'll assume is constant).
Current anywhere can be calculated from the known P of the load: I = P / Vin (where Vin is a value chosen from within the acceptable range for the Load).
The losses in the cable are given by: Vloss = I * 2R = P * 2R / Vin
Now, I want to know the required supply voltage to ensure I receive a given Vin across the load.
Vsupply = Vin + Vloss = Vin + P * 2R / Vin
If I've got that wrong I'll be embarrassed.
The thing that confuses me is looking at the equation, for plenty of values of P and R, the graph of Vsupply given Vin is hockey stick shaped. This means that (while any given value of Vin gives only one value of Vsupply) if I were to work backwards with a known value of Vsupply, reading off my graph would give me two possible values for Vin! I don't see how this can be.
Example with real values
- 18 VDC <= Vin <= 75VDC (load is actually behind a little DC-DC converter with this range of accepted input voltage)
- P = ~19.25W (calculated as the peak power drawn by the circuit on the converter's output multiplied up for efficiency losses in the converter itself).
- R = ~51R
So, it's easy to read off that if I want a Vin of 44V apparently I need to supply ~89V. But if I supply 90V, what Vin will I get? ~38V or ~52V?
I would love to understand what I'm missing or getting wrong here. Thanks.
