I have an ADC that samples 4000 times per second or 0.25 ms interval per sample. I would like to extract the RMS and frequency value of the signal being read. How do oscilloscopes and multimeters do this? The target signal is a sinewave.
I have an idea how to calculate frequency but it only works with AC. I count how many number of samples it takes from the first positive reading to change to negative and back to positive again and just multiply that by the interval. I should get the time for 1 cycle, I repeat that for the rest and average them out. Not sure if this is the best method though.
For the voltage, I get the highest and lowest reading of each cycle essentially getting Vpeak-peak. Then just divide that by squareroot of 2 and average it to the rest of the other cycles to get a better reading. Again not sure if this is the best method.
Here is a sample reading (count = 413 at 0.25ms interval). I should get an answer of around 60Hz 0.2 Vac . This is the raw voltage the ADC is reading not yet adjusted for gain.
0.173421356
0.194028019
0.211569668
0.224404791
0.234686593
0.242957526
0.250082904
0.256439526
0.261594088
0.263752444
0.264679559
0.265650304
0.266365989
0.266895564
0.267103704
0.266593726
0.261928256
0.248517781
0.228441123
0.208131004
0.186009858
0.161443396
0.13789932
0.116488709
0.095282375
0.071309289
0.044879871
0.018148901
-0.007538367
-0.031667236
-0.054018122
-0.075290975
-0.096386444
-0.117877307
-0.217307021
-0.228869418
-0.23827403
-0.245405703
-0.251243192
-0.257045347
-0.261500676
-0.263937552
-0.265401824
-0.266356262
-0.26698211
-0.267347463
-0.267451604
-0.266062148
-0.257521851
-0.240745239
-0.220487907
-0.200148034
-0.176438591
-0.151111812
-0.128481833
-0.107821382
-0.085257636
-0.059480245
-0.032984451
-0.007251693
0.017276575
0.04012342
0.061572368
0.08264309
0.104297317
0.126226059
0.147842091
0.168563338
0.189433645
0.207972933
0.221857193
0.232293061
0.240768128
0.247950727
0.254429657
0.260187752
0.263255055
0.264360126
0.265281947
0.266137393
0.266711601
0.266975816
0.266675266
0.263043912
0.251704246
0.233763913
0.213855769
0.19117844
0.166552468
0.143202656
0.121908059
0.100506032
0.076729068
0.051069981
0.024681905
-0.001622057
-0.02649937
-0.048928362
-0.069845875
-0.09085909
-0.112659372
-0.134425465
-0.155744094
-0.17640712
-0.196649289
-0.213999821
-0.226405505
-0.236240558
-0.243890076
-0.25005129
-0.255989916
-0.260918172
-0.263632281
-0.265196403
-0.266208204
-0.266830905
-0.267221721
-0.267460044
-0.26693476
-0.261019595
-0.245307427
-0.224498776
-0.205086017
-0.182742713
-0.157132263
-0.133087079
-0.112573256
-0.091028749
-0.065625294
-0.03884583
-0.013123943
0.011675407
0.03505011
0.056656701
0.077473793
0.099179089
0.121485486
0.143106096
0.163808175
0.184864734
0.20400126
0.218984582
0.23010023
0.239431028
0.246908885
0.25354746
0.259686644
0.263131888
0.264209493
0.265181096
0.266150697
0.266768821
0.267111715
0.26703461
0.264799722
0.255499107
0.237822132
0.217758348
0.196535277
0.172524568
0.148095864
0.126298443
0.105552018
0.082646237
0.056956393
0.030427412
0.004272223
-0.020932105
-0.044105392
-0.065535744
-0.08650118
-0.108058275
-0.129718653
-0.15126788
-0.172207138
-0.192875599
-0.210721804
-0.223892954
-0.234180764
-0.24245699
-0.248751241
-0.254497463
-0.259957726
-0.263198979
-0.265028604
-0.266233953
-0.266871675
-0.267277368
-0.267508396
-0.267115148
-0.262392028
-0.249209005
-0.229932717
-0.209960915
-0.187568258
-0.162448902
-0.138449781
-0.117217126
-0.045208173
-0.045208173
-0.018919232
0.006157923
0.029908851
0.051878506
0.07289029
0.09411751
0.11610991
0.138104884
0.159062452
0.17992532
0.199691987
0.21617377
0.227494124
0.236922054
0.24445098
0.251473791
0.257960589
0.262377723
0.263954003
0.264908298
0.265840705
0.266513761
0.266883834
0.266926607
0.265419133
0.257790501
0.242526655
0.22324951
0.201531196
0.17738702
0.15342452
0.131800477
0.1109522
0.088296042
0.063498838
0.037066989
0.010316564
-0.015616037
-0.039035945
-0.060208232
-0.08085681
-0.102299178
-0.124257103
-0.146093148
-0.167006369
-0.187698005
-0.206415106
-0.221140363
-0.231744746
-0.240506058
-0.24706195
-0.252951795
-0.258685572
-0.262476571
-0.264403756
-0.265740712
-0.266647514
-0.267120155
-0.267401966
-0.267375501
-0.264605601
-0.253510696
-0.234421233
-0.214074065
-0.193235516
-0.16899335
-0.143875568
-0.12197515
-0.101470196
-0.077692375
-0.051064116
-0.024750856
0.00024519
0.024409965
0.046958977
0.067974337
0.089130174
0.111248602
0.133398358
0.154533309
0.175352976
0.195526194
0.21302035
0.225329474
0.235385398
0.243500691
0.25052765
0.25689028
0.261952861
0.26385258
0.26476353
0.265686639
0.266440233
0.266922601
0.267112573
0.266387018
0.260741789
0.24630807
0.226995877
0.207087732
0.184018586
0.158831711
0.135801045
0.115240445
0.093817531
0.068910321
0.042601209
0.016381218
-0.009371139
-0.033771233
-0.056007249
-0.076902589
-0.098074877
-0.119947257
-0.141537254
-0.162501831
-0.183455823
-0.202971006
-0.218602636
-0.229613999
-0.238881283
-0.265545304
-0.266486152
-0.267075952
-0.267396673
-0.267461475
-0.26564072
-0.256300623
-0.239229755
-0.219203594
-0.198111987
-0.17396166
-0.149193782
-0.127074924
-0.1060753
-0.083089838
-0.057333047
-0.030732969
-0.005156279
0.019082739
0.041776662
0.06321059
0.084434948
0.106116355
0.128137222
0.149638671
0.17031171
0.190921663
0.209086729
0.22252753
0.232836942
0.24125164
0.248558551
0.255367643
0.2609814
0.263386376
0.264539798
0.265508826
0.26635855
0.266895707
0.267078098
0.266581567
0.262288888
0.250137264
0.189313625
0.164919682
0.049010759
0.022428277
-0.0037179
-0.028283504
-0.050600773
-0.071547183
-0.092456543
-0.114180435
-0.136012332
-0.157430381
-0.178055069
-0.198116278
-0.215291001
-0.227322606
-0.236778288
-0.244225388
-0.250276452
-0.256240541
-0.261029608
-0.263416417
-0.265281947
-0.266418918
-0.266733631
-0.267147048
-0.267439874
-0.266462549
-0.259833415
-0.244641381
-0.223683098
-0.20293653
-0.179945776
-0.155106801
-0.131721941
-0.110566534
-0.088579999
-0.063365658
-0.036948971
-0.01102009
0.013737203
0.03681765
0.058383329
0.079424868
0.101060927
0.123067203
0.144667214
0.165688439
0.186805509
