I came across a problem in an electronics textbook by William Gosling, Radio Antennas and Propagation.
Question: A space vehicle receiver, operating at 3GHz with an isotropic antenna, will respond on receipt of quanta. A pulsed transmitter with an isotropic antenna on earth has a peak power of 1MW, a pulse repetition frequency of 1000/s and radiates 1kW mean. Assuming that the vehicle cannot integrate energy between successive pulses, what is the maximum range from the earth at which it will receive signals?
I am an undergraduate and I sent this to my lecturer to help solve but unfortunately, her answer was incorrect. She came up with a maximum range of 283 000 km whilst the book gives a grossly redacted solution of simply 8000 km. I understood her approach to the problem but then she converted quanta into Joules in a way I did not understand.
I have attempted it myself to no avail.
Edit: My lecturer's attempt Lecturers attempt at the problem
My attempt using matlab: My solution My solution continued
    \$\begingroup\$ Well, it would be helpful if you added how she converted quanta to Joule. For me, this seems pretty straightforward: A photon has energy \$E=hf\$, \$h\$ being Planck's constant. 5·10⁵ photons at 3 GHz is very little energy: \$h\approx 7·10^{-34}\,\text{J/Hz}\implies h·3\!·\!10^9\,\text{Hz}\approx 2.1\!·\!10^{-24}\,\text{J}\$. Each TX pulse has 1J (don't know what we'd need the peak power for?), and all you need to do is calculate free space loss. \$\endgroup\$ Commented Feb 15, 2022 at 13:20
  • \$\begingroup\$ yes, you are correct indeed thanks. But there are two sets of antennas a) the space vehicle b) the ground transmitter. Essential, Pr and Pt. Since the energy is tiny, I am guessing the space vehicle has to come closer to earth? E = P*t, therefore the ratio of the two over the radius of the earth and RCS? \$\endgroup\$ Commented Feb 15, 2022 at 13:31
    \$\begingroup\$ You've seen my solution now you show yours. Doesn't that seem fair @Finance_sav \$\endgroup\$
    Commented Feb 15, 2022 at 13:54
  • \$\begingroup\$ If you have attempted it, why not show your solution? \$\endgroup\$
    – Solar Mike
    Commented Feb 15, 2022 at 14:04
  • \$\begingroup\$ I would ignore this part of the book and look elsewhere for more modern methods that use a couple dozen parameters to define path range, e.g. BW, bit rate SNR modulation type and probability of error , BER for a packet with CRC+FEC. This book uses non-std ways of defining Friis loss and communication range that I would not use. I relied on better tools back in the 70's during my Aerospace communcation design days. \$\endgroup\$
    – D.A.S.
    Commented Feb 15, 2022 at 14:35
Interesting question! I took a different approach that gave me the same answer as the book, so I think I'm on the right track.
The receiver sensitivity is given in terms of energy, which works out to
$$5\cdot 10^5 \cdot h \cdot f = 5\cdot10^5\cdot 6.626\cdot 10^{-34} \text{ J/Hz}\cdot 3\cdot 10^9\text{ Hz} \approx 1\cdot 10^{-18}\text{ J}$$
The transmitter outputs 1 J per pulse, so how much of this energy does the receiver intercept? That requires knowing the effective aperture of an isotropic antenna, which is basically \$\lambda^2/4\pi\$. At 3 GHz, that works out to (0.1 m)2 / 4π.
The transmitter's energy is distributed evenly over a sphere that has a surface area of 4πr2, so the surface energy density is
$$\frac{1\text{ J}}{4\pi r^2}$$
The receiver is going to intercept that density multiplied by its aperture, or
$$\frac{(0.1\text{ m})^2}{4\pi}\cdot\frac{1\text{ J}}{4\pi r^2}$$
We just need to find the value of r for which this equals 10-18 J. Rearranging terms, we get
$$r^2 \leq \frac{(0.1\text{ m})^2}{(4\pi)^2 10^{-18}}$$
Take the square root of both sides:
$$r \leq \frac{0.1\text{ m}}{4\pi\cdot 10^{-9}}$$
Which works out to approximately 8×106 meters, or 8000 km.
  • \$\begingroup\$ can I share your solution? \$\endgroup\$ Commented Feb 15, 2022 at 15:55
  • \$\begingroup\$ What do you mean? It's on the public Internet. The applicable license is here. \$\endgroup\$
    – Dave Tweed
    Commented Feb 15, 2022 at 16:02
    \$\begingroup\$ This matches the part of the lecturers attempts that @Finance_sav shared - but we're missing the rest zo no way of knowing where she went wrong. \$\endgroup\$
    – RJR
    Commented Feb 15, 2022 at 16:43
Convert quanta to energy, multiply by number of quanta then convert to power
This is based on \$E = hf\$ where \$f\$ = 3 GHz and \$h\$ is Planck's constant (\$6.6261 × 10^{−34}\$ J*s).
  • The energy per quanta is therefore \$1.99 × 10^{-24}\$ joules.
  • With \$5 × 10^{+5}\$ quanta that's a total energy of near-enough \$10 × 10^{-19}\$ joules
  • For each 1 microsecond pulse\$^1\$, that's a receive power of \$10 × 10^{-13}\$ watts or -120 dBW.
Find the link/path loss
Given that the originating pulse power is 1 MW, that's a link/path loss of 180 dB.
The Friis transmission equation for isotropic antennas in decibels
$$\color{red}{\boxed{\text{Path loss (dB) = 32.45 + } 20log_{10}(f) + 20log_{10}(d)}}$$
Where \$f\$ is in MHz and \$d\$ is in kilometres.
  • This means that \$180 = 32.45 + 69.54 + 20 log_{10}(\text{distance})\$
  • Therefore, \$78 = 20 log_{10}(\text{distance})\$
Hence, I get distance to be 7,943 km (corrected from earlier).
\$^1\$ The answer has been edited to fix a brain-fart
  • I wrongly calculated the pulse width to be 1 millisecond.
  • It's actually 1 μs and this makes all the difference.
A thousand pulses per second means a 1 ms period and, the peak:average being 1000:1 means a 1 μs pulse width: -
I guess it does agree with the book (despite the spelling mistakes).
  • \$\begingroup\$ That's a normal error rate for even english speeking authors ;). But what is the probability of error at -120 dBm \$\endgroup\$
    – D.A.S.
    Commented Feb 15, 2022 at 14:07
Let's do orders of magnitude to check whose answer is closer to right:
  • A photon has energy \$E=hf\$, \$h\$ being Planck's constant. \$h\approx 7·10^{-34}\,\text{J/Hz}\implies h·3\!·\!10^9\,\text{Hz}\approx 2.1\!·\!10^{-24}\,\text{J}\$.
  • Each TX pulse has 1J (don't know what we'd need the peak power for? It's 1000 pulses a second, each second we emit 1 kJ, so one pulse has 1 J).
  • So, the loss is 1 / (2·10⁻²⁴) = 50·10²²
  • Free space path loss is \$\left(\frac{4\pi r f}{c}\right)^2\$, with \$r\$ being the distance between transmitter and receiver.
Solving for \$r\$:
\begin{align} \left(\frac{4\pi r f}{c}\right)^2 &= 50·10^{22}\\ \frac{4\pi r f}{c} &\approx 7·10^{11}\\ 4\pi r f &\approx c· 7·10^{11}\\ r &\approx \frac{c· 7·10^{11}}{4\pi f}\\ &= \frac{3·7·10^{19}}{4·3·3·10^{9}}\text{m}\\ &= \frac{7·10^{10}}{12}\text{m}\\ &\approx 5·10^6\,\text{km} \end{align}
