I have adapted the circuit from Michael's circuit in Efficient method for isolated detection of AC voltage without a stepdown transformer to detect on either side of the positive half-cycle peaks, rather than at zero crossing. I did this for two reasons, one being that I would like to simplyfy the circuit, and secondly, to save some energy - and only drive the opto-coupler on either side of the positive peak.
Does anyone see any disadvantages/dangers with this design, besides having a much shorter time period in which to read the output pulse?
If I recorded the midpoint in time between the falling and rising edge of the output on one half cycle, I am hoping to detect within 1mS of the voltage peak.
  • \$\begingroup\$ it will detect peak. Do you have any specs for accuracy? \$\endgroup\$
    – D.A.S.
    Commented Apr 13, 2022 at 11:29
  • \$\begingroup\$ Also keep in mind that the SFH6286 (and all optos) introduce delays. This one could be up to 6µs - perhaps not important, or critical for your application. Faster ones are available if needed, like the HCPL series (100ns max.) \$\endgroup\$
    – rdtsc
    Commented Apr 13, 2022 at 12:17
  • \$\begingroup\$ Thanks Tony, I have added my desired accuracy to the bottom of the post. \$\endgroup\$ Commented Apr 13, 2022 at 13:47
Your circuit itself will not detect a peak, it will simple create a voltage range that has some transfer function that converts a half-wave rectified 240vac mains signal to a low-voltage (between 0-3.3v) that another circuit (or device) operating at this voltage range can be used to detect the peak.
Typically. A real peak detector will be a diode or other switching mechanism followed by a capacitor to trap the signal at its peak voltage and then discharged to allow another signal to captured and measured.
I would label you circuit a rectifier and level shifter.
  • \$\begingroup\$ Thanks GT, I have updated the title of this question to something which I hope is more appropriate \$\endgroup\$ Commented Apr 13, 2022 at 13:53
