I have an application where I need a digitally controlled constant current power supply capable of currents up to 50A. I have made a digitally controlled constant current power supply in the past, but only up to 200mA, and I imagine I will need very different design constraints for this one.
I have skimmed the service manuals for high current power supplies such as the HP 6259 which seem to use an array of BJTs for regulating current but I am not sure of how to re-implement this design.
I am planning to use this 12V, 50A SMPS as a 12V source capable of supplying up to 50A. I have drafted up a circuit using the HP 6259 service manual, , this Stackexchange post on BJT-controlled constant current source, and this post on running BJTs in parallel:
But I am not sure if this is correct, and even if it is, I am not sure how to calculate the relationship between DAC output and current through the load. I am also not sure how to select the specific BJT model to use or how to select the values of resistance for the balancing resistors.
If anyone could provide any advice that would be highly appreciated!
