I made the RFM96 LoRa Radio Module by adafruit communicate to each other. The next step I want to do is connect to it to a gateway, which is either the RAK7371 Developer Base or RAK2287 Concentrator Module. After connecting these gateways to The Things Network (TTN), I noticed that it doesn't get or reflect the data from the RFM96 module in the gateway. I didn't see the data I sent using the module.
After doing researches, I may have found out what might be the reason -- RFM96 LoRa Radio Module is not considered as LoRaWAN end-node as needed by the gateways.
I would like to confirm to you and hoping that someone can shed light on this matter.
Thank you!
