I've designed a LED board 8x8 where LEDs are assembled in reverse. So, there is a through hole at every LED position, LEDs assembled at the bottom, and light goes through the PCB hole and comes out the top layer.
The issue is that I notice some portion of light going through the PCB prepreg to the adjacent LED which is lit up a bit.
The first batches were OK because the prepeg had a darker color and now with a new supplier it is more transparent. What I would need is to spec the type of prepreg and core dielectrics correctly.
Which type of prepreg do I have to use to avoid LED light transmission through the PCB substrate?
This is a comparison for your consideration:
