I have a solar off grid inverter/MPPT charger and I want to install protection on the link between the unit and the battery.
I thought of using a Circuit Breaker like this. But the problem is that DC circuit breaker is directional as I understand, because you have a side that you should link to load and side to the battery. And in the case of this unit the same link to the battery can draw DC current or send it.
The question is: can I use two on serial on the same positive link each in different direction so I cover both ways? Thanks!
