I have a non-linear differential equation and want to obtain its transfer function.
First I linearized the equation (first order Taylor series) around the point that I had calculated, then I proceeded to calculate its Laplace transform. However, I could not do the last step.
The linearized function is:
$$k_1\cdot\ddot{y} = k_2\cdot y + x + k_3$$
I don't think I did anything wrong with the linearization (MATLAB gave the same result).
I just can't calculate the TF because of that k3.
Manipulating the expression I get stuck with something like G(s) = X(s) + ..., which doesn't seem to make sense to me.
The only mistake I could have made is in the calculations to find the point I needed to linearize around, but unless that point is 0 (which it is not), I will always end up with a k3, so probably that's not the problem.
What do you think? The differential equation must be wrong?
