I am trying to verify that I have correctly understood how to size a fuse to protect circuit components.
Lets assume I have a resistor model series that can tolerate 60W for 1 ms according to the datasheet (0.33W continuous). Let's also assume the resistor chosen has 1k.
For the sake of argument lets assume this resistor is connected between a voltage source and ground and shall be protected against damage by over-voltage with a fuse.
My approach would be to calculate a maximum permissible I²t rating of the fuse as follows:
R*I²t <= P*t
I²t <= P*t/R
I²t <= 60W * 1ms / 1k
I²t <= 6e-5 A²s
So any fuse with I²t < 6e-5 A²s should protect the resistor (minus some margin), right? Of course the fuse must also tolerate the nominal current indefinitely...
