I am trying to design a BJT amplifier with the given parameters and limitations. The circuit is shown below.
Parameters:
- Vcc = 15 V
- RL = 20 kΩ
- beta = 180
- Vbe(on)= 0.6 V
- Cµ = Cπ = 0
Limitations are:
- Swing voltage of Vout must be between 22 and 24 V (peak to peak)
- Voltage gain must be more than 10
- Power dissipation by resistors must be under 0.2 W
- Corner frequencies of C1, C2, and CE should be < 10 Hz
- The high threshold frequency should be 20 kHz
I assumed that Rc must be smaller than RL so I designed Rc= 2 k ohms and then I found RE1 = 180 ohms, but I have an issue where I have to design RE2. I don't know how to use 22-24 V pk-pk specification in this design.
- How do I adjust peak to peak voltage?
- How can I calculate input and output impedances and open circuit voltage gain?
- How do I approach power dissipation considerations?
As it's a homework question, I'm not looking for a whole solution, but some tips and advice.
