I am using the UCC27423DGN dual low-side MOSFET driver as a current sink in order to drive some piezo elements. In general the gate drivers I am using are inverted, so on a high pulse on the Pulse_A/B lines, the outputs Pulse_A/B_Out should drop from VDD to GND.
In the design, VDD is 10.5 V from a switching regulator, and Pulse_En, Pulse_A, and Pulse_B are all 3.3 V signals from the microcontroller.
With no output connected (no piezo element attached), on circuit startup I am seeing that the gate driver is consistently shorting the VDD signal to GND once VDD is applied, seemingly permanently damaging the gate driver. Even after removing the IC from the board, a short can be seen between VDD and GND on the TSSOP pins.
The small resistor and capacitor on the output are meant to act as a low-pass filter. As far as I know, the voltages should be within spec and the circuit fails before a load is attached. Any help would be appreciated, as I am not sure what I am missing.
