We know that we can calculate AC power using
$$ S=VI^{*}=|S| \angle \varphi . $$
Given that a grid works as constant voltage source, we can calculate the absorbed power in
$$ S = |I|^{2}Z = \frac {|V|^{2}}{Z^{*}} . $$
The problem is, I did not see any frequency on that equation. Thus, how we can approximate power consumption of electric appliances with a rating of 50 Hz connected to 60 Hz grid?
I want to know the relation on at least three kinds of appliance: synchronous motor, asynchronous motor, and resistive based appliances such as incandescent lamp. Also, how about an electronic such as laptop that has AC to DC converter?
I assume that there must be a general formula.
EDIT:
As explained here, placing an appliance in under frequency environment cause reduction in mechanical power output. What I'm understand, the electrical power consumed will also decreased.
The reverse must be true, that is placing an appliance in over frequency environment.
So, how to calculate the power consumed of 50 Hz appliance that will be connected in 60 Hz grid? I know I can just go an measure, but what I want is any equation, explanation, or any material that I can read about this.
