I'm looking on the datasheet of the BQ25798 (Buck Boost Lipo Charger) and was wondering which task the Zener Diode and the 294 Ohms Resistor has.
I had an idea that the resistor is maybe limiting the switching speeds of the two mosfets and therefor limiting inrush current? (I think I read it somewhere) But why has it to be this abstract 294 Ohms value? would 300 Ohms be also ok?
For the zener diode I haven't found any information and I have no clue for what it could be used. maybe someone could give me some hints.
Here is a typical application schematic of the ic with the two mosfets and the diode
for reference, in a dev kit they used a 12V Zener Diode. dev kit
