I built a boost converter that converts 42 V to 57 V.
While it works well with a FDH055N15A MOSFET at 20 A, I am trying to understand why it won't work properly with a HY3912W MOSFET. I only have two FDH055N15A MOSFETs left and a whole box full of HY3912W's I would like to be able to make use of.
NOTES
Inductor L22 in the schematic and pictures is bridged with coper wire of zero resistance or inductance.
I wound the inductors myself and haven't actually tested the inductance or resistance but thry works fine with thr FDH055N15A:
I am guessing that the on resistance is too high as the base pin is only driven to 12 V by the TC4420 driver that is also powered from the same rail as the fan.
I am struggling to understand from the datasheets what the difference would be if the 12V rail was increased to 18 V or 20V. I am thinking of trying to power the rail at 20 V and swapping the fan out for a 24 V fan hoping it will run at 20 V. If that is a success, re-print the boards splitting the 12 V rail into a 12 V and a 20 V rail. I rather over purchasing £7 each MOSFETS for these boards I already have.
The datasheet of the FDH055N15A shows an on resistance at 10 V or 20 V:
The datasheet for the HY3912W shows an on resistance at 10 V only:
I am not sure either will help me understand why the HY3912W runs at 20% duty cycle producing as much heat in the heatsink as actual output current where the FDH055N15A will run happily at about 12% duty cycle producing 20 A.
Am I barking up the wrong tree and just being thick? To be honest, I don't really know what I am doing, my whole life is generally just trial and error.
