I am supposed to build a boost converter that steps-up a 1.5 V input to 5 V (I only have 1.5 V as a power source). I have designed the circuit but the only problem I face right now is that I can't turn the MOSFET on with 1.5 V peak-max. I am using a B012N03LX3 MOSFET as my switch.
This is my schematic connection (assume the diode is ideal and assume that the NE555 can operate with 1.5 V which the simulation shows it can)
I checked the datasheet and I know that the Vgs(th) must be at least 1 V to turn the MOSFET on.
The NE555 has the output of this 10 kHz with 0.7 duty cycle.
But the voltage output at Vload is:
So from this I am pretty sure that the MOSFET did not get sufficient voltage at Vgs(th) to turn on. But due to the fact that I only have 1.5 V as voltage supply I am not sure what correction I need to make to my circuit to make sure that the MOSFET is able to turn on properly (with only 1.5 V as a voltage source).
BTW I think the output should look like this if the MOSFET is able to turn on properly:
So any idea on what I should change in my circuit to make it work?
