I have a question with regards to surge and continuous amperage ratings as they apply to battery disconnect switches.
I recently had a battery kill switch installed on my light duty truck as a theft deterrent. As far as I can tell it’s the Pico P/N 5575PT. (Shop supplied the kill switch and parts)
I started doing some research after the fact and found that the specs on this particular switch are 350 amps of continuous DC and 500 amps surge DC.
I’m a bit concerned now since I’m thinking that the surge current would be equal to the CCA of the battery (Duralast AGM) which is rated at 900 amps. Continuous amperage would be from the alternator which has a maximum output of 180 amps.
With all of this being said I’m now afraid that the disconnect switch itself is below where it needs to be for starting, assuming the starter pulls all 900 amps every time.
The switch itself is inline or the negative battery cable which (correct me if I’m wrong) -1.5v less than the positive terminal.
I’m hoping I’m just paranoid and overreacting to this.
What’s the worst thing that can happen assuming this switch is truly not sufficient?
