I have a signal that's output from a summing amplifier that can change between 200mV to 500mV. I would like to clamp this signal to 350 mV. That's to say that the output of clamping needs to vary as per input up to 350mV and then not increase beyond this. How can this be done?
As I understand Zener diodes don't operate at these voltage ranges. And a resistor in series with a Schottkey diode in forward bias doesn't have a sharp transition between conducting and non-conducting, so much so that LT spice simulation is showing it more like a resistor voltage divider.
What other simple options are there to achieve this goal?
