- THE PROBLEM:
I used this LDO voltage regulator (SOT223 package) with a 4.5 V input from 3 AAA batteries to provide a steady 3.3 V as output for all the other components. The voltage regulator, C7 and C8 capacitor all get really hot to the touch. There doesn't seem to be any output from the voltage regulator at all because none of the LEDs are lighting up.
The temperature of the voltage regulator from my calculations is about 109.5 degrees Celsius. The total current from all of the load is 760.5 mA and the voltage drop across the regulator is 1.2 V. With P=VI, it is about 0.912 watts. Thermal resistance of the regulator is about 120 degrees per watt thus 0.912x120-109.5 degrees Celsius. I cannot guarantee if the calculation for 760.5 mA is correct but in any case, 109.5 degree is still lower than 150 which brings me to the next section.
I hope I can get the bottom of this heat problem with some help.
- POTENTIAL PROBLEMS:
1. It is still too hot and heat is not properly dissipated
I know in electronics if something is too hot to touch then it is too hot, but in the case of this voltage regulator if it gets to 109.5 degrees, does it drive up the impedance to the point it blocks all flow of current? These two LEDS are supposed to act as indicators if there is current flow or if the board is on but neither of them light up. In this case, will putting a heatsink help at all? It still won't solve the heat of C7 and C8, though.
2. PCB layout
My power trace is 0.5 mm (19.7 mils) which I do believe is standard for power traces but is it somehow too small? Perhaps there is something wrong with my PCB layout that I am not taking into consideration?
3. My power source
Highly unlikely but there could be something wrong with the batteries? I put 3 of them in series to get a combined 4.5 V as mentioned early. 1.2 V drop shouldn't be a lot right?
4. Soldering issue
I used a stencil and relatively new soldering paste. I used a hot plate to melt the solder. I used 220 degrees Celsius for the hot plate which is well above the solder paste's melting point of 183 degrees Celsius. Should I have soldered this at a different temperature?
- ADDITIONAL PICTURES
