I have a 3.3V regulator (L78L33) buffered with a 2N2907A transistor. I am new enough that I might be doing something wrong in hooking up this circuit, so I included both the diagram (copied from the datasheet) and a picture of my breadboard.
When Vout is left floating, I get 3.301v out. But when I hook the output to a rail containing only an STM32F301 that is putting 2.2v out of the DAC. The power estimator says I should be using well below 5mA. However, the regulator voltage drops immediately to about 20mV and both the regulator and the transistor get extremely hot. I can barely touch them for an instant without actually burning myself. This only takes a second or two.
Do I have something wrong in my setup? I had this MCU hooked up to an LM317 before and everything was working fine.
I should also mention that I also tried this circuit with an MJE2955 transistor instead of the 2N2907A since I was sure that I couldn't hit the current ceiling on that. However, that transistor also got nuclear hot - hotter than the other parts, faster if that's possible.
EDIT Thanks all. After the suggestions I tried without the transistor, same results, then tried adding resistance to see how much the circuit could handle. Turns out the regulator + 2N2907 work great up until around \$100\Omega\$, when the impedance starts getting too close to the input impedance and the voltage starts dropping (but of course I expected this, and the circuit doesn't overheat even down to \$20\Omega\$). So then I thought maybe something happened to the MCU so I hooked it back up like I had it this morning with just the LM317 (at 3.3v output) and sure enough, the LM317 gives the same behavior. So I'm not sure what could have happened in the meantime to cause something like this - the LM317 even causes the system to emit a very high pitched whine... not good.
For completeness I included photos of my scope output from the L78L33 and a picture of my MCU setup, if anyone has any idea why things like this happen (I really hate having to soldier a new MCU to a breakout board :-/). The MCU pins are given here on page 33.
ANOTHER UPDATE This issue is resolved - there never was a problem. Something (ESD? Voltage jump from a discharging cap? No idea...) blasted my MCU. I have another MCU put in place now and it's working as expected. Thanks everyone for your help - I'm sorry to have wasted your time.
