I'm encountering a design issue with my switch-mode power supply that utilizes the InnoSwitch3-EP (INN3678C). The SMPS powers up and outputs the required V when the input voltage is 133VAC or higher, under full load conditions (drawing 3A), but I'm facing problems when trying to achieve reliable operation within a lower input voltage range of 85VAC to 110VAC at full load.
When I change the input to a lower voltage e.g 100VAC it does not power up. I can hear clicking noises from the SMPS, maybe stuck in auto reset mode ?
Things I have tried.
- Tried different combination of undervoltage sense resistor, still no result the minimum stayed around 130VAC.
- Shorted the undervoltage pin to source so it disables it, as per datasheet. The minimum input AC at full load was 150VAC.
- Measured across C23 on the primary bias and I can see it was oscillating until the input AC reached ~130VAC. Then it was 15V.
The power supply was designed with universal input (85V-240V). Any help on what I should try doing next?
