5
I just moved from Eagle to Altium. I cannot find SMD resistors in Altium libraries. In Eagle, there are almost all general components. In Altium there are only few resistors. Where can I download the libraries? Or, do I need to make my own for every component I use?
  • \$\begingroup\$ Which version of Altium do you use? \$\endgroup\$ Commented May 9, 2013 at 17:50
  • \$\begingroup\$ @Szymon Bęczkowski Altium 13, the latest one. \$\endgroup\$
    – zud
    Commented May 10, 2013 at 5:14
Altium 13 features Vaults as a primary means of managing your components. You will need to setup a connection to Altium's Hobart Vault (something like public repository) to access the components. Generic SMD resistors can be found e.g. under Components - Generic \ Resistors \ Basic Surface Mount.
If you want to use older library method you will need to download the 'old style' libraries from Altium Wiki.
I believe there is a library named Standards.IntLib. You might find SMD components there. Also the components you have on your schematic, go to properties and check if SMD Footprint is available for that component. If not you can make your own SMD footprints which are very easy to make. Let me know if you need any help with that.
  • \$\begingroup\$ I cannot find devices.lib and Standards.IntLib in my Altium. There is miscellaneous-Devices.Intlib which has few resistors. The only SMD resistor is 0603. But I need resistors of other packages. \$\endgroup\$
    – zud
    Commented May 9, 2013 at 5:46
  • \$\begingroup\$ @libuz, oh k then you will have to make them yourself. Would you like any help with that? \$\endgroup\$ Commented May 9, 2013 at 8:43
  • \$\begingroup\$ You can try circuithub.com - its a little buggy since I last used it but it could be better now. I believe it was made by a member here, DrFriedParts I believe. \$\endgroup\$
    – efox29
    Commented May 10, 2013 at 11:05
When I last used Altium/Protel, integrated libraries were just being introduced - I used separate schematic and PCB libraries, and, as I recall, the PCB footprint library had many SMD footprints - for resistors and capacitors, they were named by their US size designation: 1206, 0805, and so on. On the schematic for resistors I used "RES" from devices.lib. I would manually assign the appropriate footprint.
