At the start of Chapter 3 in their Analysis and Design of Analog Integrated Circuits, Gray, Hurst, Meyer, and Lewis remark that
The next three chapters analyze various circuit configurations encountered in linear integrated circuits. In discrete-component circuits, the number of transistors is usually minimized. The best way to analyze such circuits is usually to regard each individual transistor as a stage and to analyze the circuit as a collection of single-transistor stages. A typical monolithic circuit, however, contains a large number of transistors that perform many functions, both passive and active.
It is this last sentence which I'm not following. In what sense is a function "active" or "passive"? Is this a colloquialism for the fact that some transistors are just there to bias etc. others, and these others "actively" do the amplification or whatever the function of interest is? I ask because it seems the use is different than that alluded to in circuits textbooks, as discussed here for example.
A MOS transistor (a PMOS, generally) can be used as an on-chip weak pull-up (This is quite a common approach that can be seen in today's MCUs). So the transistor here is used as a passive device.
An NMOS with gate and source shorted together can be used as an ESD protection diode which is a passive device (Here, not the MOSFET itself but its body diode is actually used but those two are not considered two independent components). This also is a common method in IC design.
You can see a lot of BJTs with base and collector shorted together are used as diodes inside, for example, op-amp chips. That's another passive function There are those who claim that a diode is an active device, but let's ignore it for now.
Active functions must be the functions that the transistors are used as active devices such as switches or amplifiers.
PS: I don't have the book, so I can't check if it's explained somewhere. But maybe you can.
