I have a camera lens with auto focus. I opened it and found a tiny (2x1 mm) IC. A search on Google for "auto focus IC" showed it has 6 pins (GND, Vcc, SDA, SCL, and 2 outputs for the voice coil), and I2C communication.
The number on the IC is AKM 30 5F 45. If I don't have the datasheet, how can I determinate what Vcc, ground, and the data lines on the PCB are? It has exposed a four pin pad. It is from a S4 GT-i9500 back camera/rear camera.
IC number:
Four pin pad
Voice coil IC and capacitor:
