It is for reverse voltage protection (hooking up the battery or power supply backwards across the input supply terminals). The zener diode and resistor are to stop the MOSFET gate-source junction from blowing due to overvoltage. This is because the MOSFET gate-source voltage limit is lower than the source-drain voltage limit. It would not be required if the expected voltage supply was lower than the MOSFET gate-source voltage rating.
It does almost the same thing as a diode except for two points:
- The diode has a higher forward voltage drop and thus more losses
- The diode will protect against a reverse-current protection whereas the PMOS, as shown. This is also known as a "load-dump" and is when the load pushes current back towards the input power supply. This can happen if the motor starts generating, or if the input power supply is something like a bench supply but is unplugged from the AC wall outlet with all the bench supply's internal component still connected to the motor driver.
The simply reason why the simple PMOS circuit as shown does not protect a reverse-current scenario but a diode will is that the PMOS circuit relies on the voltage across the input terminals to operate whereas a diode does not. A diode only relies on the voltage across the terminals of the diode itself to operate.
Overcoming this flaw requires additional circuitry for the PMOS circuit.
See this for more information for more details on the operation, behaviour, and solutions:
nmos reverse current protection
