I'm building a multi device using canbus for communication and have a few questions.
The image below illustrates my setup with multiple canbus wiring possibilities for devices. The big pcb called MAIN PCB have around a 30cm copper traces around the pcb and multiple connectors for devices to connect to directly to the can bus network. Added resistor termination directly to the MAIN PCB can bus because all the devices are optional to the network. All wiring also connects GND signal.
I was hoping to achieve up to 1Mbps using CAN 2.0B.
- There could be multiple Device type A/B using multiple connectors, each one up to 40cm stub. Can this be a issue?
- For devices type C/D, can both work or the D type add to much stub?
- For device C type, the idea is to avoid using too long stubs, each device would have 2 different can bus links and would route canbus packages between them. Daisy chaining them. Is this a good idea?
- What kind of connectors could be recommended in this example?
