Can anyone help me identify the component in the attached picture? I've never seen a similar package.
1\$\begingroup\$ Might be HSOP-6J package ablic.com/en/doc/package/FH006-A.pdf \$\endgroup\$– vivierCommented Mar 16 at 22:17
\$\begingroup\$ Darn... That dot is covering up the first two numbers/letters of that part number. Curses to the manufacturer for their obfuscation! \$\endgroup\$– ColinCommented Mar 16 at 23:52
\$\begingroup\$ Great! It could be a regulator from ablic! I was reading 1428 but probably the last character is B. In this case it could be S-1142B33I \$\endgroup\$– salvatore cirasaCommented Mar 17 at 7:56
Add a comment
1 Answer
Yes you probably right, the only findable designation with 142B and 33I in the second line is S-1142B33I prefix (HSOP-6J package from ABLIC). The marking clearly corresponds.
Nothing found with 1428.
