Let me provide a different way of looking at it. It may be simpler to see your question with regard to \$R_1\$ and \$R_2\$ using math.
Let's keep the BJT base current in place and assume that it is some unknown value called \$i_{_\text{B}}\$. Let's consider the inward injection of a very tiny current called \$i_{_\text{0}}\$. The KCL for your blue node, call it \$v_{_\text{X}}\$, is then:
$$\frac{v_{_\text{X}}}{R_1}+\frac{v_{_\text{X}}}{R_2}+i_{_\text{B}}=\frac{v_{_\text{CC}}}{R_1}+\frac{0\:\text{V}}{R_2}+i_{_\text{0}}$$
or, solving for \$v_{_\text{X}}\$:
$$v_{_\text{X}}=\underbrace{v_{_\text{CC}}\cdot \frac{R_{2}}{R_{1} + R_{2}}}_{\text{quiescent DC voltage}}+i_{_\text{0}}\cdot\underbrace{\frac{R_{1} R_{2}}{R_{1} + R_{2}}}_{\text{what }i_{_\text{0}}\text{ sees}} - i_{_\text{B}}\cdot\underbrace{\frac{ R_{1} R_{2}}{R_{1} + R_{2}}}_{\text{what }i_{_\text{B}}\text{ sees}}$$
There are three terms there. The first term is just the usual voltage divider result. The second and third terms are how the injected and base currents affect the result. These last two currents each see what appears to be the standard parallel resistor equation.
(You can also disconnect the base current -- set it to zero -- and this simpler equation still shows the parallel combination of \$R_1\$ and \$R_2\$ applied to \$i_{_0}\$.)
Another viewpoint that is often suggested is that the impedance of a voltage supply is zero. So \$v_{_\text{CC}}\$ connects to ground with zero impedance. And therefore looks like a wire. You could imagine that \$v_{_\text{CC}}=0\:\text{V}\$ and then you would know that it is a wire. But if \$v_{_\text{CC}}\$ is any other fixed value, that makes no difference to this viewpoint. It's all the same. The voltage supply looks like a wire.
But the equation makes this equally clear in a different way.
