I have an LCD display that I want to re-use. It is attached to the PCB via a flat flex cable, which I believe is ACF bonded:
Ideally I want to remove the cable intact, and then fit it to a socket instead of bonded to a PCB.
I've been having trouble finding information on how to do this. I am aware of G450 which is supposed to free ACF bonded cables, but can't find much information about its use for that purpose. Everything seems focused on cleaning up after removing the cable, with little concern for damaging it.
I have seen suggestions to apply Kapton tape and use heat, but I am worried that would melt the cable. I'm not sure how it was bonded in the first place, if heat was used or just adhesive.
How can I remove and re-use this cable in a socket? Or at least bond it to my own PCB.
Edit: 3M has a guide: https://multimedia.3m.com/mws/media/501881O/3mtm-anisotropic-conductive-film-adhesive-5363-rework-process.pdf?&fn=5363_ACF_6002969.pdf
It looks doable, probably the solvent method is the place to start as with only a basic heat gun and soldering iron it will be difficult to apply the recommended 150°C temperature. Also you need the solvent to clean it up anyway.
Still, I'd like to hear from anyone with experience, or other ideas/comments.
Edit: 99% IPA doesn't work.
