If my V_in is a sinusoidal voltage, what would be the V_out?
I tried to plot this in ltspice, however, I ran into trouble on where to connect the ground, on what node should I use to extract V_in and V_out from.
I also tried to use basic diode analysis like assuming the diode is conducting and find out what should be the value of V_in for the current to flow from anode to cathode. But I don't know how to do that if it's on the negative side of the terminal.
