I have a specific application in mind, but a more general question regarding diode stacks.
System overview:
We have a constant-current source which is driving a constant current through a magnet. We need the current to stop fast (<1 μs) and without remaining current (<1%).
We have two different switches in the application. One is regulating the current "current_regulator" and the other one is stopping the current close to the magnet "fast_switch".
When the fast switch opens, the 600 A go through the diode into a 100 nF capacitor. The 100 kΩ resistor discharges the capacitor slowly. There is 100 ms before the next pulse.
Specific question regarding the diode stack:
We have "High Voltage Diode Assemblies" in our lab that can handle these currents and voltages easily, but they are costly.
I know that I have to balance a diode stack with resistors and this works on a longer time scale. But during the initial switching moment (200 μs) the voltage across the diodes is distributed very unevenly. This means that when the current through the diodes stops flowing the reverse voltage is building up. Then for over 200 μs the voltage is balancing through the resistors.
I wanted to see whether the diodes or the mechanical setup were the problem and swapped the diode order from 12345 to 3 4 5 1 2, but the problem is always with the same diode and is not influenced by the diode position.
I went on and removed diodes 4 and 5 completely from the circuit, but then I had the same problem with diode 3. It looks like the diodes have different capacitances or stop conducting at slightly different times.
To measure the voltages I used a "TT - SI 9010A differential probe", input impedance is 50 MΩ and 10 pF. I also tried to add the five curves in the scope and compare the result with the measured voltage over all 5 diodes in series. The curves look identical.
I used STTH1512W diodes that I bought in the same package from a distributor; the date codes are also identical.
Now I have hopefully given enough information and still not so much that nobody is willing to read this. But I would be very curious what I have to do to get a balanced and fast diode stack, preferably even faster than 100 ns.
The diode would probably not be my first choice, but I had it available. Are there maybe diodes that should be used instead? Although I have a rather high current of up to 600 A, the current only flows for about 1 μs and only ten times per second.
I would like to stack many more diodes in the future but before I can do that I have to understand the underlying problems.
Thanks for you time.
