I'm trying to understand this common emitter amplifier that is part of the of a guitar pedal. The image is take from the ElectroSmash analysis from the Big Muff Pi .
The values for R6 and R4 are clear for me. 10KOhms is a common value in guitar pedals and 3.3KOhms for R5 makes sense since the desired gain is moreless G=4.5, and the gain of this amplifier is R=R6/R5. However, i don't understand the value for R3. As far as i know the "rule of thumb" in a common emitter amplifier is that I_r3 > 10*Ib. I have calculated the quiescent current of the schematic to be around 0.375mA for the collector, so it should be around 3.75uA for the base current. The tension for the base in the Q point is supossed to be around 1.3V. So the current in R3 will be I_r3 = Vb/R3 = 13uA which is not bigger than 10x3.75uA. Am i missing something here? Thanks!!
