I am trying to sample the voltage drop across different components at high frequencies, and figured the best way to do it was with an instrumentation amp so there's not much additional load placed on the main circuit, and then feed that output into a peak detector to get a dc value. I found an amp that looked like it would work in LTspice, but the output of the amplifier (red) is not matching the voltage drop across resistor Rm (green). Changing the supply voltage, gain, and values of Rm/R4/C1 do not change the output of the amp.
Is the idea itself wrong or am I using the incorrect amp for this application?
