I'm trying to replacing a broken switch in my 1986 Corvette. It's in the door panel which can be pressed to turn the door panel interior light on and off. The switch itself has only the manufacturer marking and no part number (mfg: Judco). Looking at Digi-key I believe I've found the switch, at least, the dimensions match:
https://www.digikey.com/en/products/detail/judco-manufacturing-inc/40-3658-01/611173
I want to make sure the switch behaves the same, but I don't understand the functional description in the data sheet:
Please help me understand what "ON A - ON A&B - ON B OFF" means so I can test the switch in the other door, which is functional, to make sure this is the same part.
Also, how can something be a "4 way" switch as stated in the description with only 3 wires?
