For a project I'm working on, I wanted to clone this e-paper driver board and eventually integrate it into my project's board. Here's a part of the schematic:
However, with my custom prototype clone that I did with EasyEDA, I lose almost all of my signal when I connect the e-paper display over an extender flex cable. The signal that I'm focusing on for testing is the GDRH signal which turns on the mosfet Q1. The image below shows the original board by Good Display that I'm trying to clone, connected to the e-paper display.
Here's how the GDRH signal looks like on the original Good Display board, measured directly at Q1:
It looks the same with or without the extender cable. The on-phase is 1.5us wide and the rise and fall time is roughly 30ns. Here's my clone board connected. Yes it's very crude and full of engineering sins because I'm a beginner:
Now here's the signal without the extender cable:
Even though the display is connected directly to the board, the signal has already deteriorated alot. The on-phase is much shorter and the rise and fall times are much longer. In this configuration the display still works fine. This is the signal with the extender cable attached:
There's barely anything left. The on-time is so short, that the image quality of the display is significantly degraded. The signal looks like this even when measured on the display side.
As a beginner I have no idea what went wrong. My best guess is that the connector I used in my design, which isn't the same model as the one used in the original board, introduces more resistance beween the extender cable and the board and this creates an RC circuit. But can that really be? I have no reason to assume that this connector is worse than the original. The cable fits tightly and when pressing on the cable and connector it doesn't change the signal.
I also can't imagine that it's the mosfet, but for reference here's the one used in the original and here's the one I used. I also didn't add a ground plane because I didn't know how to do it at that time. Here's my PCB layout. The line in question is highlighted and was auto-routed.
Keep in mind that the particular line I measured for testing is only connected to the connector, the gate of the Q1 mosfet and the R2 1MΩ pull-down resistor (well, and my probe). I double checked my design to make sure I didn't accidentally connect another component, and I didn't. Any explanation for why the signal is so much worse on my board?
Update:
