I have a square wave 0-12 V input signal that varies from 30-150 Hz, which I wish to multiply to an output square wave 0-12 V signal of 60-300 Hz. In this case, the multiplier is 2, however I ideally need this to be adjustable as I am not sure exactly what it needs to be — it could be anywhere from 1.6-2.4, but will not need to be changed once the correct value is found.
Is there an IC, or circuit, that can be made using simple components to achieve this, where changing the value of one component alters the multiplier?
