The sound coming from the speaker cuts out and just hums loudly whenever I touch or displace the unplugged RCA cable.
How do I get rid of this noise? The whole should be somewhat robust. The speaker and amplifier will be moved around constantly so I expect the cables to move frequently.
The unplugged RCA is part of a stereo pair. Since the speaker and configuration of the amplifier is meant for mono I only use one of the RCA cables. So one of them just dangles unconnected. On the other end, the RCA pair is connected to a Bluetooth-module via a 2x RCA to 3.5 mm jack (TRS) connector.
I am using a
- STEVAL-CCA044V1: class-D amplifier board
- VHM-314: Bluetooth-module
- Qoms2: Monopole omni-directional speaker
Before the Bluetooth-module and amplifier used to be powered with the same battery supply but the output kept varying in volume over a set of time. So after reading about the potential problems of a ground loop problem or bad decoupling of the power supply, I tried using an external supply for the Bluetooth-module which seemingly helped with the varying output.
