Sorry if this question is not perfectly on topic, but I could not locate a better forum:
I have a USB memory stick ("SanDisk Ultra Fit (0781:5583), but actually many sticks behave similar) that is usually connected via a USB-2 cable to my PC. I noticed that the tiny stick gets quite warm, even when sitting idle.
Today I had connected the same stick to a USB-3.2 docking station, and when pulling it out I had realized that it was almost so hot that I could not touch it.
Again the stick was idle most of the time (I know that SSDs become quite hot when writing data, but not when "sitting idle").
I'm by no means a USB specialist, but my thought are like this:
- Both, USB-2 and USB-3 power the stick with 5V, and the controller when being idle should do the same things, whether connected to USB-2 or USB-3 when idle.
So why is it getting much hotter when connected to USB-3? - What does such a controller do when "sitting idle"?
- Don't high temperatures increase the leakage current, shortening the time the bits are safely stored in the flash cells?
Windows (using USB-2 cable) lists these device properties:
Aktueller Energiestatus:
D0
Energiekapazität:
00000019
PDCAP_D0_SUPPORTED
PDCAP_D3_SUPPORTED
PDCAP_WAKE_FROM_D0_SUPPORTED
Energiestatuszuordnungen:
S0 -> D0
S1 -> D2
S2 -> D2
S3 -> D2
S4 -> D2
S5 -> D3
Information I found was not really helpful:
- What Causes USB Flash Drive High Temperature
- Answers to Why will a USB flash drive get so hot when plugged into a Windows computer?
- Hot Stuff! Why Does My Usb Flash Drive Burn My Fingers?
Updates:
As it had been suspected that the convection via cable makes a difference, I connected the stick to the docking station via an USB-3 cable. The temperature measured was about 60°C of the surface (using a contact-less infraread sensor).
Now a really curious fact:
As I had experienced a rather hot USB stick (Kingston Data Traveler 16GB) on my Fritz Box 7490 using USB-3, I had switched the port to USB-2. Now I wanted to switch it back to USB-3 to see a temperature increase of that stick, too (to prove the theory that USB-3 makes sticks becoming hotter). The temperature with USB-2 was about 35°C before, but surprisingly about 10 minutes after having switched the port to USB-3 the temperature descreased to about 29°C. However I had turned on the option "USB-Festplatte bei Inaktivität in den Energiesparmodus versetzen" (Put the USB hard disk to energy-saving mode when inactive) to 10 minutes.
Final Update
I wouldn't believe if I hadn't experienced myself: After some Windows updates the same stick on the same hardware doesn't get hot any more! I can only assume that some power-saving methods are used now (while a file is open on the stick, so it was not "ejected").
The energy data now look like this:
D3
Energiekapazität:
00000019
PDCAP_D0_SUPPORTED
PDCAP_D3_SUPPORTED
S0 -> D0
S1 -> D3
S2 -> D3
S3 -> D3
S4 -> D3
S5 -> D3
