On a power supply board for an X-ray sensor (PAN Sirona) we are getting -9v from an LM137 fed by an LM2672 generating -12V from +5V. The circuit is likely like that (it is not easy to make sure it is exactly like this since it is a multilayer board):
Is there an application note that specify the usage of LM2672 to get a negative voltage since the datasheet doesn't mention this kind of usage?
