I'm designing a small device (lighted arrow nock) powered by a CR435 pin battery, which looks like this. The pin at the top (1.0mm diameter) is the negative terminal, and the body (4.0mm diameter) is the positive:
I'm having trouble finding some way to connect this to the PCB. I was thinking of maybe using a fuse holder (at least for the positive connection), but I'm further restricted that the whole thing should fit in around 6mm (the inside diameter of an arrow).
I'm also okay with just connecting the pin and simply wrapping a wire around the body. And it doesn't necessarily have to be held tight either, it just needs to make proper contact. I don't want to solder directly to the pin either, since the battery should be easy to change.
