For my job I sometimes have to install an electromagnetic door lock. This comes with a power supply (24 V, 5 A), depicted in its manual thusly:
I understand that 220 V (for the Netherlands) powers this power supply, and outputs 24 V, 5 A.
My first question is: in the specifications you can see a magnet logo, and “1×5 A / 250 V” and “1×10 A / 250 V”. What does this mean, because all the magnets run on 24V, none of them run on 250V.
As I understand, voltage must be equal on the supplier and the supplied (power supply outputs 24 V, magnet must be 24 V), but the amperage can be different, but in one way: the amperage of the device (or devices) must not exceed the supplied amperage (in this case 5A). So why does it say “1×10 A” when the power supply outputs only 5 A?
As there are two outputs, my assumption is that either output has 24V 5A. There is no mention of this in the manual, and the customer service of the manufacturer is not helpful at all, but could it be that you can somehow combine to the two outputs and have 5 A + 5 A = 10 A?
The magnets that are used with this power supply run on 24 V, 1.25 A switch-on voltage and 275 mA continuous voltage. Is it then true that I can have (5000 mA / 275 mA) = ~eighteen 24 V electromagnetic locks? Or should I look at the switch-on voltage (5 A / 1.25 A) and have four 24 V electromagnetic locks?
You could also get a 12 V power supply and have a magnet with 12 V, 1.5 A switch-on voltage, and 550 mA continuous. Why would I choose a 12 V over a 24 V power supply? You could argue it would less cost to run, but why then not use the more cost-efficient one?
Thank you.
... almost everything in the picture is numbered ... please use the reference numbers \$\endgroup\$
