This may be a simple question, but it is something that I can't seem to wrap my head around.
I have a +12v 5A power supply at work which has two knobs, one for voltage and one for current.
There are various devices that upon plugging them in I have to increase the current otherwise they will not work, but when I do this, the voltage level stays the same.
My question is, what exactly is happening when I turn the amperage knob on a benchtop power supply? My guess would be that we are changing the resistance being supplied to the device but I am unsure and would love a real explanation!
Thanks!
    \$\begingroup\$ Basically the output current is measured (through a shunt resistor) and compared to a reference value (which you set with the knob). The result of this measurement influences the voltage regulation circuit such that it decreases the output voltage to not exceed the current you chose. You should watch this EEVblog video: youtube.com/watch?v=CIGjActDeoM where it is all explained. \$\endgroup\$ Commented Jun 25, 2017 at 20:43
Here is one current-limiting circuit
You most likely have a switching power supply that measures the current through a shunt resistor before the output voltage is measured - because the two are in series the power supply knows the output current is the same as the shunt current
The logic then follows something like if the voltage is less than the knob set, and the current is less than the knob set, then turn on the switch, and if it's higher on either, turn off the switch - then after the switch there is a smoothing capacitor or similar to reduce the ripple to where you won't notice it
For most uses of a bench power supply you're interested in providing a steady voltage. That's what the voltage setting is for. The current setting is a current limiter -- if your load draws more current than you've set the limiter for, it lowers the voltage until the load draws only the amount that you set the limiter for.
The idea is to keep your electronics from frying if you've made a mistake.
