This may be on the limit of ATTiny13 possibilities, but still: is it possible to connect ATTiny13 to USB to get ADC readings (one way)?
According to this article http://www.vk2zay.net/article/211 (and my understanding of it) it seems doable, though the size of the serial communication program takes a lot of memory.
However, instead of max232 I have Micro USB to Serial Adapter from microbot (http://www.microbot.it/products/mr002-002-1.php ). (Well, I also have max3323 chip, but I would like to spare it for something else).
I am aware of this question: How can I communicate between micro-controller and PC without the use of RS232/USB Adapter?
but can't quite understand why max232 is needed in between?
UPDATE: I can't find any better datasheet on the adapter, but it uses MCP2200 chip.
UPDATE 2: as Passerby answered below, one can connect attiny directly to the microbot's adapter. For the record, these are changes I made to above mentioned project to make it work:
Line 52 of the code needed "const": const unsigned long mags[10] PROGMEM = {... to make avr-gcc happy.
Pin 6 of the attiny needs to be connected to RX of the adapter (attiny can use Vdd and Gnd for 5v power)
I have not set any fuses with avrdude (removed them in Makefile)
Baud rate in my case was 1200, and all it took to see the output of attiny was cu -l /dev/ttyACM3 -s 1200 (I guess, cu does some magic to the adapter in the beginning to set the baud rate). Baud rate has been calculated by looking at the pin 6 output with oscilloscope, which gave about 0.8 ms min pulse width. (cu is Linux/Unix serial utility, another one tried is minicom)
The datasheet for the adapter is not enough. I needed to look up MCP2200 chip's specs to make better guesses
